The car stop in the middle of traffic
TOYOTA
WEEWEEUN
I have a scion Xa 2004 with 65000 miles. This morning, I was driving on the freeway where the car stop reacting. When i tried to press the gas paddle, the car is not accelerating, instead the car is slowing down in the middle of freeway. I rolled the car to the side of the freeway. Afterwards, a cop showed up and push my car to the closest shoulder where my car is in neutral position. When i tried to step on the brake paddle, it is not responding also. At last, i have to pull the hand break to stop the car. When the toll truck showed up, they charged my battery because when my car is pushed by the cop, the battery icon showed up on my dashboard. After they jumb my car, it works fine. The battery was replaced two weeks ago. During this weekend, i did a service where they replace the front and rear brake, 2 belts, flush the coolant, oil change, change the oil filter and air filter, change the spark plug.
What could be the caused of this problem? I am not sure what to do.
Oct 8, 2007 at 5:49 AM
Probably the battery was too low unable to power the igntion system and caused it to stall. I recommend you have the charging system check to include a drainage test on the electrical system-
Something cause it and you don't want to face the same problem at the freeway-its your safety. Remember those cars/trucks are moving fast and they don't know your intention.
Oct 8, 2007 at 6:09 AM
WEEWEEUN
[quote="rasmataz"]Probably the battery was too low unable to power the igntion system and caused it to stall. I recommend you have the charging system check to include a drainage test on the electrical system-
We couldn't find anything wrong with the car. But when we were testing the Xa, we found out that the RMP is pretty low. If we clean up the throttle body, will this help the situation? Is there anything we can do to locate the problem?
Oct 8, 2007 at 11:53 AM
Find the idle air control valve or the idle speed control motor remove and clean all gummed area and varnish. Then inspect/test the trhottle position sensor voltages close and open volts.
In the event the TPS checks out-replace the IACV but do this again find the EGR and clean out the carbon and make sure its getting vacuum.Before you replace the IACV. Then report back everything you've done.
Oct 8, 2007 at 2:35 PM
