my tourque converter is grinding against the atf pump houseing
Mar 17, 2006 at 2:05 PM
✓Experienced Mechanic
The Flywheel is bolted to the rear of the crankshaft, now the torque converter is bolted from the front of the flywheel to the converter.
Probably the front pump is loose-if not stabbed properly the tranny w/n bolt up to the engine.
Mar 17, 2006 at 6:58 PM
