1986 Toyota Tercel Broken Pump Arm
DOUGC
86 Toyota Tercel Wagon 4cly with 100,000 miles. I replaced a leaking fuel pump yesterday, however did not install the new one correctly and approximately 2" of pump arm broke off inside engine. Will the broken piece drop harmlessly to the sump or does the engine need to be taken apart to retrieve?
Dec 4, 2006 at 8:54 PM
  • 75,988 POSTS
[quote:4e2737f815="dougc"]86 Toyota Tercel Wagon 4cly with 100,000 miles. I replaced a leaking fuel pump yesterday, however did not install the new one correctly and approximately 2" of pump arm broke off inside engine. Will the broken piece drop harmlessly to the sump or does the engine need to be taken apart to retrieve?[/quote:4e2737f815]
take the intake manifold off -it'd not make it to the crankcase-it stays there forever-if not remove can move around and damage the valve train.
Dec 9, 2006 at 1:09 PM
Suggested Repair
Remove the intake manifold and retrieve the broken fuel pump arm. It will not fall into the crankcase and can move and damage the valve train if left in place.
Conversation Summary
The owner of a 1986 Toyota Tercel wagon broke about 2 inches of the fuel pump arm inside the engine while installing a replacement pump incorrectly. The expert advised removing the intake manifold to retrieve the piece, explaining that it will not reach the crankcase and can damage the valve train if left.
