fuel pump location
1990 TOYOTA TERCEL
63,000 MILES
TOYOTATERCEL
cant find were the fuel pump is in a 1990 toyota tercel i popped the rear seat off and thought it was the pump but it is for the gas gauge and no pump thanks for the help i think its the EL tercel.
May 8, 2013 at 9:13 AM
90 was carb. it is on the intake manifold. it is a mechanical fuel pump
roy
May 8, 2013 at 9:28 AM
WRENCHTECH
  • 20,761 POSTS
If it is a sedan, it will be carbureted but if it was a hatchback, it is fuel injected and the pump is inside the tank. The tank has to be removed to access it.
May 8, 2013 at 9:53 AM
TOYOTATERCEL
It is a sedan so it is a mechanical fuel pump? Is it even worth fixen then thanks
May 8, 2013 at 10:23 AM
TOYOTATERCEL
Asemaster6371 thanks alot went and bought the mechanical fuel pump today and it was a simple fix for somebody who has never worked on a vehicle... cars running great thanks
May 9, 2013 at 2:42 PM
