If they replaced the VC gasket they may not have set it down on the front seal properly, or maybe that needs replaced as well. You didn't mention the engine size, but lots of yotas have overhead cams that require seals on the ends of the V cover, right above the Timing belt.
SPONSORED LINKS
Friday, May 18th, 2007 AT 4:32 PM
