Please submit instructions for finding top dead center of number 1 piston on compression stroke for 1992 Toyota 4A-FE engine.
Mar 23, 2006 at 8:23 AM
Remove the No. 1 spark plug, cover the hole with cloth, and seal it with your thumb. Disconnect and ground the coil wire to the distributor. Crank in short bursts until compression pressure is felt, then stop. Turn the crankshaft center bolt to align the vibration damper notch with 0 degrees. Confirm the piston is fully up and that the distributor rotor points to the No. 1 plug tower.
The owner asked how to find top dead center of the No. 1 piston on the compression stroke for a 1992 Toyota 4A-FE. The expert advised removing the No. 1 plug, feeling compression pressure while cranking with the coil wire grounded, aligning the damper mark to 0 degrees, and verifying piston height and rotor position at the No. 1 tower.
