1998 Toyota Tacoma Speedometer Quits
TOYOTA
TGRU
I have a 1998 Toyota Taoma 4x4 4 cyl. My speed. is dig. readout the last 2 times I drove it the speed. quits the tach the milelage and then it comes back on after I crank it again.The last time I drove it it done the same thing this time the check eng. light came on but it went out the 3rd time I drove it I call toyota and they said they never heard an speedometer problem like this so this is new to them. Please let me know what to do and maybe I can fix it. My milelage is 93,000 Thank You Randy.
Apr 6, 2007 at 4:28 AM
  • 75,988 POSTS
[quote:3eda163505="tgru"]I have a 1998 Toyota Taoma 4x4 4 cyl. My speed. is dig. readout the last 2 times I drove it the speed. quits the tach the milelage and then it comes back on after I crank it again.The last time I drove it it done the same thing this time the check eng. light came on but it went out the 3rd time I drove it I call toyota and they said they never heard an speedometer problem like this so this is new to them. Please let me know what to do and maybe I can fix it. My milelage is 93,000 Thank You Randy.[/quote:3eda163505]
Have the vehicle speed sensor check at the tranny-Be advised that toyota may have 2 one at the dash.
go for the tranny 1st.
Apr 6, 2007 at 8:50 PM
TGRU
Thank you for the reply, how would I go about checking the tranny to find out the problem, also would I need to buy a meter to check this. Thank You Randy.
Apr 7, 2007 at 1:14 AM
  • 75,988 POSTS
[quote:f58238ca54="tgru"]Thank you for the reply, how would I go about checking the tranny to find out the problem, also would I need to buy a meter to check this. Thank You Randy.[/quote:f58238ca54]
Take it out-turn key to On-now spin it while someone look at the speedo if wiggle/fluctuates-its not engaging the gear in the tranny.
BTW toys are known to have 2 one at the dash-its a very tricky device to deal with
Apr 7, 2007 at 11:17 AM
TGRU
Thank You I'll Try that, I also was told there is a speed sensor control on ether the side or top of the tranny he said its got 1 screw and a wire harness and also he said the same thing you said the gear in the tranny is that true about the wiring on the tranny. Thank you Randy
Apr 7, 2007 at 12:54 PM
  • 75,988 POSTS
[quote:7c67b68c69="tgru"]Thank You I'll Try that, I also was told there is a speed sensor control on ether the side or top of the tranny he said its got 1 screw and a wire harness and also he said the same thing you said the gear in the tranny is that true about the wiring on the tranny. Thank you Randy[/quote:7c67b68c69]
@ the tranny the VSS sometimes just not engaging right therefore its not spinning inside and not giving an AC signal back to the computer.
Apr 7, 2007 at 7:24 PM
Suggested Repair
Check the transmission vehicle speed sensor first. Remove it, turn the key on, and spin it while someone watches the speedometer; if the reading does not fluctuate, the sensor is not engaging the transmission gear or sending an AC signal to the computer. Toyota may also have a second, harder-to-service speed sensor at the dash.
Conversation Summary
A 1998 Toyota Tacoma owner reported the digital speedometer, tachometer, and mileage display quitting, then returning after restarting; the check engine light came on once and later went out. The expert advised checking the transmission vehicle speed sensor first, noting it may not engage the gear or send a signal, and that Toyota may also have a second sensor at the dash.
