Toyota Tacoma Brake Pedal to Floor
CALEB82
I have a 200 tacoma prerunner. when brakes are applied, the pedal travels almost to the floor before the truck stops. pads and shoes are new. fluid is full. Help! :?:
Feb 1, 2006 at 3:29 PM
CHEVY350GUY
  • 109 POSTS
bleed the system. are there a ny lights on?
Feb 2, 2006 at 11:05 AM
CALEB82
No lights on
Feb 2, 2006 at 4:01 PM
CHEVY350GUY
  • 109 POSTS
bleed the system. if there is air in it the peddel will have excessive travel.
Feb 3, 2006 at 3:54 AM
Suggested Repair
Bleed the brake system to remove air, which can cause excessive pedal travel even with full fluid and new pads and shoes.
Conversation Summary
The owner of a 2000 Tacoma Prerunner reported that the brake pedal travels nearly to the floor before the truck stops, despite new pads and shoes and a full fluid level. No warning lights were present. The expert recommended bleeding the brake system, explaining that air in the lines can cause excessive pedal travel.
