1999 Toyota Tacoma Manual Trans Cooler
99TOYTAC
1999 Toyota Tacoma PU
2694cc engine
132K miles
Stick Shift
4-wheel drive
No leaks or strange sounds
No past repairs - all specified maintenance performed
I just inherited a travel trailer and have never pulled one before. Trailer weighs 3000 lb unladen, hitch wt 300#. The Toy's combined wt rating is 7400 lbs so I reckon it can pull it, maybe not up logging roads but on normal highway grades.
The post on how manual transmissions work clearly explains why no transmission cooler is needed, but does not mention towing. Many trailer part vendors seem to advise getting a cooler. I don't even see how it would be possible to hook a normal transmission cooler to a manual transmission. Seems like I would only need to change the gearbox oil more frequently. But just be be sure, do you agree?
Aug 11, 2007 at 5:16 AM
  • 75,988 POSTS
[quote:c537024587="99toytac"]1999 Toyota Tacoma PU
2694cc engine
132K miles
Stick Shift
4-wheel drive
The post on how manual transmissions work clearly explains why no transmission cooler is needed, but does not mention towing. Many trailer part vendors seem to advise getting a cooler. I don't even see how it would be possible to hook a normal transmission cooler to a manual transmission. Seems like I would only need to change the gearbox oil more frequently. But just be be sure, do you agree?[/quote:c537024587]
You won't be needing a cooler-all it needs is to maintain the gear oil and keep the cooling system up to snuff-you'll be fine.
One last thing keep it Tune-up. A weak engine performance will cause a problem climbing hills and other weird stuffs such as fuel economy etc.
Good Luck! Have a nice day
Aug 11, 2007 at 9:04 AM
99TOYTAC
Thanks Raz! I may have thought so, but I breathe easier after someone more skilled agrees.
Aug 11, 2007 at 11:32 AM
  • 75,988 POSTS
[quote:16127659f5="rasmataz"][quote:16127659f5="99toytac"]1999 Toyota Tacoma PU
2694cc engine
132K miles
Stick Shift
4-wheel drive
The post on how manual transmissions work clearly explains why no transmission cooler is needed, but does not mention towing. Many trailer part vendors seem to advise getting a cooler. I don't even see how it would be possible to hook a normal transmission cooler to a manual transmission. Seems like I would only need to change the gearbox oil more frequently. But just be be sure, do you agree?[/quote:16127659f5]
Also if you wish you can get an adapter that fits the oil filter housing for an in and out flow thru an oil cooler upfront-helps keep the engine temperature down and a quickie change of the oil filter instead of going underneath its very convenient it works for me, I wish all of them are made like that. Getting Old
Good Luck! Have a nice day[/quote:16127659f5]
Aug 11, 2007 at 1:01 PM
Suggested Repair
No manual transmission cooler is needed for towing. Maintain the gearbox oil, keep the engine cooling system in good condition, and keep the engine tuned. An optional oil-filter adapter and engine oil cooler can help control engine temperature.
Conversation Summary
The owner of a 1999 Toyota Tacoma with a manual transmission asked whether a transmission cooler was needed to tow a 3000 lb trailer. The expert said a cooler is not required and advised maintaining the gear oil, keeping the cooling system healthy, and keeping the engine tuned. An optional engine oil cooler was also mentioned to help control engine temperature.
