2007 Toyota Tacoma Vibration Shudder
WONDERING_SPIRIT
My new truck has a problem that Toyota acknowledges, but doesn't know how to fix it. So they say it is typical but not normal. (???) So I thought that you might have a suggestion.
The truck has a vibration/shudder when it shifts gears up or down and is most noticable when slowing at 25MPH until about 10MPH and sometimes all the way down to zero and continues at idle. It seems to be getting worse. When I drive thru the neighborhood at 20 - 25 MPH, the virbation continues and feels like I'm driving over small rumble strips. The truck has 7,500 miles and I first noticed it about a week after I bought it - don't know if it was there originally or not.
The Toyota regional guy recorded the symptoms and sent the data to HQ - says they wonder (?) if it is in the torque converter.
The truck is 4.0L Auto 4x4 & problem occurs in 2 or 4 wheel drive. Tires/wheels have been ruled out.
What is your best guess? Thanks so much.
Mike Titus
Feb 3, 2007 at 2:20 AM
CARUNDELL
  • 602 POSTS
[quote:9c0bca5389="Wondering_spirit"]My new truck has a problem that Toyota acknowledges, but doesn't know how to fix it. So they say it is typical but not normal. (???) So I thought that you might have a suggestion.
Mike Titus[/quote:9c0bca5389]
Mike,
Torque Converter sounds like the culprit! Yet if ya got the "big guns" from "yota" on it .....well, can only say, patience is a virtue. Let us know what they say, so we can stay on top of this one!!!
Regards,
Chris
Feb 3, 2007 at 6:19 AM
LOSONE
  • 1,616 POSTS
I had the same problem with my 2006 Tacoma. It turned out to be a bad motor mount. They are made with a lock plate that will hold the engine in case of failure. They cahnged all three mounts and it corrected the problem.
Good luck Lsosone
Feb 5, 2007 at 3:34 AM
CARUNDELL
  • 602 POSTS
[quote:d7118479d1="losone"]I had the same problem with my 2006 Tacoma. It turned out to be a bad motor mount. They are made with a lock plate that will hold the engine in case of failure. They cahnged all three mounts and it corrected the problem.
Good luck Lsosone[/quote:d7118479d1]
Lee,
Thanks for the input and fix!
Chris
Feb 5, 2007 at 3:40 AM
WONDERING_SPIRIT
[quote:e4bd17280e="losone"]I had the same problem with my 2006 Tacoma. It turned out to be a bad motor mount. They are made with a lock plate that will hold the engine in case of failure. They cahnged all three mounts and it corrected the problem.
Good luck Lsosone[/quote:e4bd17280e]
Toyota is not going to move on my problem - so I'm thinking of having the mounts replaced. Do you know which mount was bad, or do you think all 3 must be done?
Thanx, Mike
Mar 12, 2007 at 11:02 AM
Suggested Repair
Inspect the engine mounts and replace all three if worn or failed, as that corrected the same shudder on a similar Tacoma. If the mounts check out, continue investigating the torque converter that Toyota suspected.
Conversation Summary
A 2007 Toyota Tacoma with 7,500 miles shudders or vibrates during upshifts and downshifts, especially while slowing from about 25 mph to 10 mph and sometimes at idle. Tires and wheels were ruled out, and Toyota suspected the torque converter. One expert agreed the torque converter was likely, while another reported the same symptom on a 2006 Tacoma was fixed by replacing all three engine mounts. The owner asked whether one specific mount or all three should be replaced, but that detail was not answered.
