1989 Toyota Pickup 4x4 won't engage
1989 TOYOTA PICKUP
215,000 MILES • 4 CYL • 4WD • MANUAL
MATSIERRA
When I shift into 4 wheel drive, the 4x4 light comes on but I can tell I am still in 2 wheel drive. Truck has manual hubs and they are locked. The left side hub, however, will not unlock. I can not turn it to the free position. The other hub will unlock and lock. No recent work or changes on the truck.
Aug 7, 2010 at 2:45 PM
KHLOW2008
  • 41,814 POSTS
Hi matsierra,
The left wheel hub seems to be the cause of the problem. You need to disassemble it to check why it is stuck.
Possibly due to lack of lubrication internally and it has seized.
Aug 8, 2010 at 1:16 AM
