1995 Toyota Tacoma Overheating
Did you have the heads milled/shaved?
The heater core won't cause the overheating problem
but i took the center head off and was able to pour water thre the heads which came out the thermostat hole , have i got the head gaskets on wrong.
The center head-you're probably talking about the intake manifold.
It suppose to come out from there to go back to the radiator. Double check all the hoses going to the radiator and resevoir end to end make sure its not plugged-up.
Check the fan clutch by doing this: start the truck up till its warmed-up, then shut it down-turn the fan by hand some drag will be present-if it freewheels easily or locked-up replace the fan clutch.
Remove the thermostat run the engine without it-overheating still present? if so put Stat back and do the above mentioned.
In conclusion if it persist-have it pressure tested to include the Rad cap.
BTW did you find out what caused the overheating to do all these damage.
Suggested Repair
Confirm coolant hoses to the radiator and reservoir are clear end to end. Check the fan clutch after warmup (it should have drag, not freewheel or lock). Test-run without the thermostat, then pressure-test the cooling system and radiator cap. Also check for a plugged catalytic converter causing back pressure. A heater core flush is unlikely to fix overheating.
Conversation Summary
A 1995 Toyota Tacoma SR5 overheated severely, damaging valves, lifters, and cams. After head work, new head gaskets, water pump, timing belt, thermostat, and a cleaned radiator, it still overheats and runs otherwise. The owner wondered if the gaskets were installed on the wrong side after water poured through the heads came out the thermostat opening. Experts said that flow path is expected, the heater core is not the cause, and advised checking hoses, fan clutch, thermostat, system pressure and radiator cap, plus a possibly plugged catalytic converter.
