Read....... if your car stall when stop
TOYOTA
ROCK2001WWF
  • 10 POSTS
For those toyota cars stall when stop, go to change the coolant temperature sensor.
I did mine with my friend, it's working fine now.
Don't go to the dealer to change it,
it can be done easily, any mechanics can do the job.
Good luck.
Apr 21, 2006 at 12:55 PM
LOSONE
  • 1,616 POSTS
I have made this suggestion on a number of posts. thanks for the insight.
Apr 22, 2006 at 1:31 AM
ROCK2001WWF
  • 10 POSTS
The stalling problem still exist, I don't know what to do now.
Apr 24, 2006 at 12:15 PM
LOSONE
  • 1,616 POSTS
Go back to basics and ask your self if this vehicle didn't have all the electronics what could be the problem. WE are back to fuel, spark and compression in time.
The idle in older vehciles was contolled by changing the idle air controls on a carb. Now we deal with Idle Air Controllers. It is the module that opens and closes allowing more vacuum into the intake controlling the idle.
A few whiles ago I had an idling problem with a Toyota truck. It turned out there was a piece of lint stuck in the mass air flow sensor.
Let me know the engine, tranny , vehicle type, mileage and engine and I will try and help. Good luck
Apr 24, 2006 at 12:28 PM
ROCK2001WWF
  • 10 POSTS
My corolla is 1993, automatic, 1.8 liter 16 valve, EFI,
144300 miles.
Right now I am thinking could the problem caused by the Engine speed sensor?
By the way, my old model car can't read the rpm, so is there a device I can use to check the rpm of my car?
Thanks for the help.
Apr 27, 2006 at 11:09 AM
