Toyota No-Start After Jump
TOYOTA
NICHOLAS8
After I get my battery jumped, the car runs fine and even starts fine. But around the second time I start the car I here a click and then nothing. The car won't start. I have possible causes swimming through my mind. But I need someone who's an expert give me possible causes.
Jul 15, 2006 at 3:32 PM
  • 75,988 POSTS
Check your alternator
Jul 15, 2006 at 10:24 PM
DJ_2CB
  • 8 POSTS
Could be your battery is old and needs to be replaced (doing a load bearing test on battery works good after its fully charged - prob parts store or a mechanics shop can test it out for you)
Also check for corrosion and bad connections, sometimes those will make a vehicle not start. If there is alot of white chalky corrosion around terminals on battery clean it off with a wire brush, and some battery terminal cleaner (can be bought from most parts stores)
If it just clicks and doesnt start, it could be in the starter.
Usually it will start after try a few times, and happens to not catch in a certain area.
The alternater you can check by hooking up a electrical meter to and while running if your voltage drops it is most likely that.
Averagly good voltage is above 13 volts. When starting and then letting idle - it should be about 12 V and go up to about 13-15 volts.
Jul 31, 2006 at 4:55 PM
Suggested Repair
Check the alternator output while running; voltage should rise from about 12V at idle to roughly 13-15V. Also load-test the battery, clean corroded terminals and connections, and inspect the starter if the car only clicks and will not crank.
Conversation Summary
A Toyota starts and runs after a jump, but on a later start it clicks and will not start. Advice was to check the alternator, test the battery, clean corroded terminals and connections, and consider the starter if it only clicks.
