1986 Toyota Corolla Intermittent No Start
TOYOTA
GIS STUD
I'm a diesel mechanic (and a poor one at that!) so I have some questions for those that might know a little about spark.
The car: 1986 Toyota corrola.
The Problem: Starts sometimes but not other times. This all started 3 days ago. My girlfriend went to work and the car would not start after work. She jumped it (I'm very proud, though she did complete the circuit by grounding at the battery) and still no start. She called me, by the time I got there it was running.
What I have done so far: Battery was old so I replaced it.
When i try and start, sometimes everything is fine. But sometimes, I turn the key to accessory and I hear a real weird nosie under the hood, low volume.Then it will not start. When I hit the starter nothing happens, not even that dead battery ticking niose from the starter.
I am assuming that an electric part is failing but not completely failied. I cannot think of a way that the starter switch would do this. So i started to think about the distributor. Since it moves, I could see it fail;ing selectively. But I don't know anything about gassers. So, what would you guys start testing/replacing and how would you test it?
Also, at the moment i am having difficulty reproducing the problem but I know it will happen again, soon as she is far from home on a cold night.
Thanks,
Steve
Feb 21, 2006 at 3:01 PM
GIS STUD
as a follow up:
It seems like it is not even trying to turn the starter motor over. I am not sure that a distributor would produce these symptoms, seems I should be able to hear it cranking but not firing if it were a distributor.
-Steve
Feb 21, 2006 at 3:04 PM
FISHERMAN
  • 937 POSTS
check your battery connectors and your clean ground cable, if the car has a molded cable-connector check that first, there is cases where that connector its not making a contact with the cable (got insulated with corrosion) and its not visible...
if the connectors are in good shape and tested check your connexion on the starter (its the first place where the current (+) goes)
Let us know what do you find...
Feb 22, 2006 at 3:51 AM
Suggested Repair
Inspect and clean the battery connectors and ground cable, including any molded cable connector that may be corroded and not making contact. If those connections test good, check the positive connection at the starter.
Conversation Summary
A 1986 Toyota Corolla intermittently fails to start and sometimes does not crank at all, with no starter click. The battery was replaced. The owner first suspected the distributor, then noted the starter is not even trying to turn. The expert advised checking the battery connectors and ground cable for hidden corrosion, then checking the starter connection if those are good.
