not starting
TOYOTA
TIM ARAGON
  • 5 POSTS
Was in a hurry and needed to jump start my car. In my rush I crossed the jumper cables. Obviously, wont start. I have checked all the fuses efi relay and open curcuit relay. I cant really hear the fuel pump anymore but everything seems to be ok. The car turns over with an occassional sputter.
Any suggustions!
signed. Bonehead move
Apr 29, 2007 at 8:21 AM
  • 75,988 POSTS
[quote:52756ebed2="tim aragon"]Was in a hurry and needed to jump start my car. In my rush I crossed the jumper cables. Obviously, wont start. I have checked all the fuses efi relay and open curcuit relay. I cant really hear the fuel pump anymore but everything seems to be ok. The car turns over with an occassional sputter.
Any suggustions!
signed. Bonehead move[/quote:52756ebed2]
Recheck the COR and check the MAF sensor this is the one that completes the ground circuit for the F/Pump.
Also jump BATT and Fuel pump terminal at the diagnostic connector link-do you hear the pump?
HTH Good Luck
Apr 29, 2007 at 8:54 AM
TIM ARAGON
  • 5 POSTS
[quote:fdb63b3828="rasmataz"][quote:fdb63b3828="tim aragon"]Was in a hurry and needed to jump start my car. In my rush I crossed the jumper cables. Obviously, wont start. I have checked all the fuses efi relay and open curcuit relay. I cant really hear the fuel pump anymore but everything seems to be ok. The car turns over with an occassional sputter.
I have now checked the voltage to the pump and disconnected to line at the filter to see if I am pumping anything. I am getting 11.5 vlots at the pump connector and fuel is being pumped from the line. With the ignition on and I plug and unplug the relays I still get an audible click from the fuel sel and the open circuit relay and the efi relay. Could I have damaged the igniter?
Any suggustions!
signed. Bonehead move[/quote:fdb63b3828]
HTH Good Luck[/quote:fdb63b3828]
Apr 29, 2007 at 10:23 AM
  • 75,988 POSTS
Disconnect a spark plug wire and ground it while cranking , do you have spark?
Apr 29, 2007 at 5:29 PM
TIM ARAGON
  • 5 POSTS
yes I have spark. After car sat a while with battery disconnected the car actually started but then sputtered and went back to its normal routine.
T.a.
Apr 30, 2007 at 4:15 AM
