1969 Toyota Corona Overheating
1940 TOYOTA
MTOM
Hey all.
Got an overheating question I was hoping someone might be able to shed some light on. The car's a 1969 RT-40 Toyota Corona with an auto transmission and a 1500, 2R engine.
On an interstate drive a month ago I got serious overheating problems. Granted it was pretty hot outside for most the trip, but I boiled it a few times and I've never had over heating probs with this car before. The problem arose after some time, too. It was not an issue until I'd covered a few hundred kms. More so, I'm not sure I've got rid of the problem yet. Basically, it runs above the normal operating temp at speeds over 80kms (50mls) per hour. Getting normal operating temps running around the suburbs, but not out on the highway.
Originally thought it was a cooling problem. Took out the thermostat. This brought the temps down a bit, but it's still too high at higher speeds. The water pump is new and I've got loads of water passing over the top of the radiator core. The fan belt is tight and the radiator core is only about three years old. So, I'm guessing that the cooling system is okay.
Now, I've just checked the timing with a strobe light and discovered it was significantly advanced, so I've returned the timeing to 8*BTDC. I'm yet to test the car. Will do so on the next hot day.
Seeing as I don't think the problem is due to cooling and the timing was out, could some please confirm the likelyhood of the timing causing the problem and why does advanced timing cause temps to rise at higher speeds?
All input appreciated.
Cheers,
Matthew.
Feb 25, 2007 at 5:55 PM
  • 75,988 POSTS
Pressure test your radiattor cap-
Retarded or Overadvance timing will dogged the engine and create pre-ignition and detonation-one fires before ignition and the other fires after ignition.
If Rad cap checks out-Do a combustion leakage test to rule out blown headgasket, also a bloc check will do the trick when it changes color from blue to yellow.
Feb 25, 2007 at 7:34 PM
KRYPTONITEFUSION
  • 15 POSTS
maybe its the electrical system...try replacing the water temperature sensor. i think only the dealer would carry this. it seems like u've checked the rest...thermostat, coolant, leakage, etc. i wouldn't think its the water pump but seems like u did it anyways.
Feb 26, 2007 at 12:13 PM
MTOM
Think I got the solution. Radiator 50-60 % blocked. Junk mvoing through the coolling system after an engine rebuild and a long interstate drive. Ta for the in put everyone.
Cheers,
Matthew.
Apr 24, 2007 at 10:08 AM
Suggested Repair
Pressure-test the radiator cap. Confirm ignition timing is not over-advanced, since incorrect timing can cause pre-ignition, detonation, and higher temperatures. If the cap tests good, do a combustion leakage or block test to check for a blown head gasket. Also consider a partially blocked radiator if debris has circulated after an engine rebuild.
Conversation Summary
A 1969 Toyota Corona RT-40 with a 2R engine overheated on a long interstate trip and still ran hot above about 80 km/h, while suburban driving stayed near normal. The owner had a new water pump, a fairly new radiator, a tight fan belt, and good coolant flow; removing the thermostat helped only slightly. Timing was found significantly advanced and reset to 8 degrees BTDC. An expert advised pressure-testing the radiator cap, noting that incorrect timing can cause pre-ignition and detonation, and recommended a combustion leakage or block test for a blown head gasket. Another reply suggested the coolant temperature sensor. The owner later believed the radiator was 50-60% blocked by debris after an engine rebuild.
