1974 Toyota Corona Running Hot
TOYOTA
DDONLEY
I have a 1974 Toyota Corona with 117 thousand miles on it. It is a 2.0L straight four, manual transmission. It is running hot, and leaking oil. The radiator is not even close to full but the overflow tank for the antifreeze is more than full. I assume this is why it's running hot. I can't find any blockage in the hoses. If you could give any suggestions on why this may be that would be appreciated. Thanks alot.
David
May 24, 2007 at 4:24 PM
  • 75,988 POSTS
[quote:3523c834ad="ddonley"]I have a 1974 Toyota Corona with 117 thousand miles on it. It is a 2.0L straight four, manual transmission. It is running hot, and leaking oil. The radiator is not even close to full but the overflow tank for the antifreeze is more than full. I assume this is why it's running hot. I can't find any blockage in the hoses. If you could give any suggestions on why this may be that would be appreciated. Thanks alot.
David[/quote:3523c834ad]
For a quick cheap fix -change the radiator cap and thermostat.
May 24, 2007 at 8:05 PM
Suggested Repair
Replace the radiator cap and thermostat as a quick, inexpensive first step for the overheating.
Conversation Summary
The owner of a 1974 Toyota Corona 2.0L reports overheating and an oil leak. The radiator is low while the overflow tank is overfull, and the hoses show no blockage. The expert recommends replacing the radiator cap and thermostat.
