86 toyota van 2.2 still running hot
1986 TOYOTA
SPOOKIECHILD
it keeps overheating on the freeway , i have replaced the thermostat and the raidator . what do i do ? should i remove the thermostat , and operate without it ?
still stressing out
spookie child :x
Apr 25, 2007 at 8:45 PM
DAWN27
  • 6 POSTS
First replace radiator cap, if this doesn't work have the cooling system pressure tested for very small leaks that you can't see. The cooling system must stay pressurized in order to run normal..
Apr 26, 2007 at 4:19 AM
