99 Toyota Solara Problem
1999 TOYOTA
CJ23TWOTRAY
Toyota Solara, 1999, 80,000 miles, V6.
Usually after long drives after 30 min or so as I come to a stop my engine starts to feel like it is being over worked and starts to make a sound as if it is about to die out but it doesn't. The RPMs fluctuate when i come to a speed lower then 5MPH. When i reach my destination I try to figure out what exactly is going on so i turn my car off and open the hood. If I try to start it immediately after being turned off it will crank but wont start. If I let it sit for a few minutes it eventually starts up again. Could it be the alternator? I have no idea. I just changed the battery a few months ago so i dont think it could be that. But it just feels like the car isn't putting out enough power or something. This only happpens after long drives but otherwise its fine. Please help me!
May 2, 2007 at 9:25 PM
SERVICE WRITER
  • 9,123 POSTS
It may be worthwhile to check the codes in the computer, that may give you something to work with.
How old is the fuel filter?
May 2, 2007 at 10:04 PM
CJ23TWOTRAY
Im not to sure how old the filter is because I just bought the car about 6 months ago. should I try having it changed? How do I check the computer codes?
May 2, 2007 at 10:09 PM
SERVICE WRITER
  • 9,123 POSTS
If it was mine I certainly would. Take a look at the plugs as well ( not that that would be your prob).
The codes can be read with a code reader that you can buy, or pay a shop or stop at an autozone and they check them free.
May 2, 2007 at 10:17 PM
CJ23TWOTRAY
Hmmm.... Someone told me to check the spark plugs as well before. Well im gonna try to change the filter and get the codes read as well. I hope this can resolve the problem. I am totally lost when it comes to cars so thanks a bunch!
May 2, 2007 at 10:22 PM
SERVICE WRITER
  • 9,123 POSTS
Keep in mind the code is just a starting point, not a magic bullet. There are a list of maintenance items that should be done if you don't know that they were done. We can go through that after the problem is resolved if you like.
May 2, 2007 at 10:58 PM
CJ23TWOTRAY
can I still do the computer code test even tho there are no check engine lights on my dash?
May 3, 2007 at 8:54 AM
SERVICE WRITER
  • 9,123 POSTS
Codes can get listed regardless of the check engine light. This is where I always start. Maybe there won't be codes, but if there is you have an angle to work with.
May 3, 2007 at 1:16 PM
KASRAHOUSH
I have this same issue, same 99Solara SLE V6. I'm changing the EGR valve, and have been using supreme gas and changing my oil more often. on top of that, I've had an oil leak which has forced me to almost completely flush the system with new gas over time since I've leaked so much. since this time, the symptom of really hard idling leading to a stall has not happened - the stall also caused the breaks to weaken, and the lights to go dim a little bit as the engine undulated from enough energy flowing into the engine to what seemed like minimal energy flowing into it, causing it to die. when it undulated far too low, it would just stall and die.
i'm wondering if the symptom will happpen anymore. i'm considering a transmission flush as well, and i'm going to use full synthetic oil from now on only. any input?
Aug 15, 2010 at 7:19 AM
