1999 Toyota Excessive Back Pressure
1999 TOYOTA
CHUCK38
Engine sounds like it has excessive back pressure. Car will not operate above 3000 RPM. Engine will not pull car on any hill. But once car is going it will maintain speed until another hill. Also power brakes are out but have fluid. 4 cyl 120,000
Jul 15, 2007 at 11:00 AM
  • 75,988 POSTS
For power Check the exhaust for restriction ( Cat )/coolant temperature and oxygen sensors. for the brake, check the vacuum hose/check valve to the booster for a start.
Here's some more on the O2 sensor:
With engine OFF, connect the negative lead of the DVOM to engine ground. Set the DVOM to read DC VOLTS. Disconnect the oxygen sensor (O2S) electrical connector and connect the positive lead of the DVOM to the oxygen sensor signal wire.
Start engine. Create a lean condition, disconnect a vacuum line for 10 seconds. Voltage should decrease to 0.2 volt or less and remain there.
Create a rich condition, shoot some carburetor cleaner into the throttle body, for 10 seconds. Voltage should increase to 0.8 volt or more and remain there.
If sensor fails to vary according to the test steps above, the sensor is defective.
Connect sensor and clear codes.
Jul 15, 2007 at 11:06 AM
Suggested Repair
Check the exhaust, especially the catalytic converter, for restriction, and test the coolant temperature and oxygen sensors. For the weak power brakes, inspect the vacuum hose and check valve to the brake booster.
Conversation Summary
A 1999 Toyota 4-cylinder with 120,000 miles sounds like it has excessive back pressure, will not run above 3000 RPM, and will not pull hills, though it can hold speed once moving. Power brakes are weak despite having fluid. The expert advised checking for a restricted catalytic converter, coolant temperature and oxygen sensors, and the booster vacuum hose and check valve, and outlined a basic oxygen sensor voltage test.
