1995 Toyota Celica Emergency Brake Lockup
TOYOTA
RAYZNTAY
  • 8 POSTS
What will happen to your car(front wheel drive) if you are going 70 miles+ an hour and you put the emergency brake on???? Does it strip the gears, or ruin the transmission, or gerk the rear end out? And no... it didn't roll :) All I know is now it won't go forward anymore (even in gear) and when it is put back into park it makes a hugeeeeee noise ! Come on now..surely someone knows what could have possibly happens to this car lol... I am seriously desprate. Since this is my only TRANSpertation :) All ideas excepted ..none turn down or away !!! Thanks in advance..[/url]
Apr 30, 2006 at 3:42 PM
LOSONE
  • 1,616 POSTS
Firssts I need to know what kind of vehicle, tranny and mileage. I can guess that you have fried the rear brakes and they have melted to the drum--not a good thing to do unless it is an emergency and the other barkes have failed. Good luck
May 1, 2006 at 4:04 AM
RAYZNTAY
  • 8 POSTS
It's a 95 toyota celica w/ 142,884 miles
May 1, 2006 at 5:48 AM
LOSONE
  • 1,616 POSTS
auto or standard??
May 1, 2006 at 6:21 AM
RAYZNTAY
  • 8 POSTS
it's a auto
May 1, 2006 at 11:26 AM
LOSONE
  • 1,616 POSTS
drive about 30 and put it in neutral. If the noise remains the same it is the brakes. If it goes away, it's the driveline. let me know.
May 1, 2006 at 1:33 PM
RAYZNTAY
  • 8 POSTS
Maybe you did not understand the question or I did not make myself clear enough lol...The car (front wheel drive 95 celica gt toyota) was on the expressway going about 70+ and he put emergency brake on! Now...what will it cause. The car will NOT move !! Neither drive, reverse nor park. I put it into gear..and ...nothing!! I put it back into park and it grindssssss its way back in. Did pulling the emergency back (gradually) damage something? Thanks..
May 2, 2006 at 4:38 PM
LOSONE
  • 1,616 POSTS
Ahh-hah! I am glad you explained the problem. What ever or who ever put the brake on at 70 was very lucky you are here to tell the story.
You have either melted the rear barkes or a brake component broke and jammed a wheel. The emergency brakes operate only on the rear wheel.
Jack up the rear wheels one at a time. Put the car in neutral and see which wheel won't turn by hand. I expect only one wheel is jammed. After that, depending on your level of experience, remove the tire and then work on getting the hub/caliper off and see what happened.
Let me know
May 3, 2006 at 12:22 AM
Suggested Repair
Jack up each rear wheel with the transmission in neutral and see which wheel will not turn by hand. Remove the tire and inspect the rear hub and brake for melted shoes or a broken component that jammed the wheel. The emergency brake acts only on the rear wheels.
Conversation Summary
The owner of a 1995 Toyota Celica automatic said the emergency brake was applied at over 70 mph. The car no longer moves in drive or reverse and grinds when shifted into park. The expert said the rear brakes may have melted or a brake part jammed a wheel, and advised checking which rear wheel will not turn by hand before removing the tire and inspecting the hub and caliper.
