1999 camry 130,000 miles automatic V6. Check engine light on. Codes show a random/multiple cylinder misfire with individual cylinder misfires listed also. Misfire occurs during acceleration or under any load. The misfire is very inconsistent some days are better than others but the misfire is always present and noticible. Replaced plugs, wires, coils, fuel pump, fuel filter. Moved injectors around to see if the current code would follow the injector, negative. Compression consistent on all cylinders. Tested MAF sensor resistance, within specs. Please help I'm out of money and I can't keep throwing parts at this car in desperation. Thanks
Oct 19, 2007 at 7:48 AM
