87 van coolant flush
1987 TOYOTA
WICK
87 toyota van 2.2l 2wd continues to overheat, but no coolant leaks exist except for overflow tube on resevoir spews when car overheats, thus losing coolant. Don't see any water in oil. I've removed the thermostat in order to further troubleshoot. replaced radiator cap. I intend to install a Tee in heater inlet hose to do a reverse flush, but am not sure of which hose. Where is it located. Further, I replaced the water pump during cooler winter months and am wondering if I did something wrong. Can't find a picture to tell me, but is there any chance I could have installed propeller backwards? Have looked down radiator cap upon first starting car and there is fluid movement/pressure, but can't tell if it's flowing in correct direction (towards upper hose). Any way you can think of, short fo pulling water pump again, to eliminate that as the culprit as opposed to a blockage in colling system.
May 25, 2007 at 10:35 AM
  • 75,988 POSTS
[quote:15744f471c="wick"]87 toyota van 2.2l 2wd continues to overheat, but no coolant leaks exist except for overflow tube on resevoir spews when car overheats, thus losing coolant. Don't see any water in oil. I've removed the thermostat in order to further troubleshoot. replaced radiator cap. I intend to install a Tee in heater inlet hose to do a reverse flush, but am not sure of which hose. Where is it located. Further, I replaced the water pump during cooler winter months and am wondering if I did something wrong. Can't find a picture to tell me, but is there any chance I could have installed propeller backwards? Have looked down radiator cap upon first starting car and there is fluid movement/pressure, but can't tell if it's flowing in correct direction (towards upper hose). Any way you can think of, short fo pulling water pump again, to eliminate that as the culprit as opposed to a blockage in colling system.[/quote:15744f471c]
Check every hose attached to the radiator, make sure its clear, when done fill it up and purge the air out by loosening a heater hose or its own air valve.
May 25, 2007 at 4:25 PM
WICK
failed to mention in original post that have already checked for collasped hoses, checked both inlet and outlet hose to make sure they're clear, and purged air by repeated top offs. Location of heater inlet hose would be very helpful as i'll be doing backflush later today.
Thanks for your previous replay.
May 26, 2007 at 2:13 AM
