Runs great with no problems but heavy white smoke out of exhaust.No water in oil,no oil in water,Blown head gasket?Fastest way to check.Thankyou
Jan 7, 2007 at 5:36 AM
SERVICE WRITER
✓Experienced Mechanic
There is a chemical that can be added to the coolant that will pick up exhaust fumes and change colors.
Compression test the cylinders and check the plug conditions for wetness or coolant burnt signs.
Crank the engine over with the plugs out and see if coolant shoots out and plug holes.
Jan 7, 2007 at 5:57 AM
[quote:e90d252cf4="leroy"]Runs great with no problems but heavy white smoke out of exhaust.No water in oil,no oil in water,Blown head gasket?Fastest way to check.Thankyou[/quote:e90d252cf4]
Is it overheating and hows your brake fluid level? Try checking your oil might be diluted with gas.
Jan 7, 2007 at 8:15 AM
