Water Overflow in reservoir
TOYOTA
SKMASSIH
I have a 1992 Carmy XLI with 110,000miles. For the past two months every 2 days the water has been spurting out of the coolant reservoir. It started happening like once a month and now it is more frequent. What causes the water to leave the cooling system completely. Of course when this happens the car overheats.
May 31, 2006 at 5:18 AM
BOND007
  • 5 POSTS
Sounds like you have an overheating problem which is building up pressure and causing the coolant to be pushed out of the overflow. Have your water pump and thermostat checked out.
May 31, 2006 at 11:11 AM
