Temperture gauge not working
TOYOTA
RALPH53
Make Toyato
Year 1998
Millage 144,000
4 cylinder
4 will drive
I have replaced the CoolantTemperature Sending unit
I have also replace the Engine Coolant temp. Sensor, and the temperature gauge still is not working.
Mar 16, 2007 at 12:36 PM
MIKE H R
  • 3,094 POSTS
are thesending unit getting juice? use a test light take the wire of the sending unit. you can also ground the wire and see if the temp guage goes up.
check the fuses for the guages.
Mar 16, 2007 at 1:51 PM
RALPH53
I forget to tell you that I have checked all my fuses
What wire are you talkiing about grounding to get the temp gauge going up.
Thanks Ralph
Mar 16, 2007 at 2:06 PM
