Sorry about the late posting. I've been gone for a while and just getting up and running again. Still trying to keep up. If you look on top of your engine, you should notice the line of injectors near the intake. There may be a fitting or a valve on the rail somewhere. If you have access to a fuel pressure gauge it should have an adapter with it to hook up to the fitting. Otherwise you can loosen the fuel line fitting. Then turn the key on but don't try to start it. If the fuel spits out a lot, you most likely have good fuel pressure. If not, check the fuel filter for clogging. If you need more help, let me know. I'll try to do better about keeping up.
Dave
Friday, January 25th, 2008 AT 10:17 PM
