1991 Toyota Landcruiser
WSMITH108
  • 1991 TOYOTA LANDCRUISER
  • 6 CYL
  • AWD
  • 175,000 MILES
My 1991 landcruiser doesnt like to start when the outside temp gets above 80 after it has been in stop and go traffic, any ideas?
Monday, April 12th, 2010 AT 2:49 PM
Next time it happens-do below immediately to determine whether it's fuel or spark issue:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Monday, April 12th, 2010 AT 2:58 PM
