will not start after long trip
300,000 MILES • 4.5L • 6 CYL • 4WD • AUTOMATIC
BRASSTACKSCREATIVE
My vehicle has always been reliable until now. After a long journey where engine has chance to really warm up it cranks over but will not start. After cooling it will then start. I suspect plug leads and rotor, but it could be a sensor or ignition issue. I know this question has been asked before but wondering if anyone has a specific issue that is causing this?
Thanks, Phill
Jun 25, 2017 at 1:12 AM
HMAC300
  • 48,601 POSTS
scan for codes and see if it is a crank or cam sensor, also sometimes coolant temperature sensors will cause problems too.
Jun 25, 2017 at 3:24 AM
BRASSTACKSCREATIVE
Okay, solved my issue after talking to Toyota mechanic. It was the EFI relay. I was able to "hop" the car back to the house by removing relay tapping it on the road reinserting it then starting back up until it stalled out again. Just ordered the new relay and hope to be back up and running soon.
Jun 25, 2017 at 10:40 AM
  • 55,770 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers, Ken
Jun 28, 2017 at 4:40 AM
