Hi there,
You will have a 2H engine, things to check is the EDICT motor operating, that the motor on the side of the block with the rod going to the injector pump, it should move with the ignition turned on, this is what turns on the fuel, check glow duration, how long does the primary glow stay on for? Is the lift pump picking up fuel, crack an injector line at the injector and crank over is there any fuel? (Don't take pipe of just undo a few turns Start here.
Mark (mhpautos)
SPONSORED LINKS
Monday, February 1st, 2010 AT 3:37 AM
