1985 Toyota Landcruiser 2h diesel cuts out and restarts aft
GORDONMOB
  • 1985 TOYOTA LANDCRUISER
  • 6 CYL
  • 4WD
  • MANUAL
  • 350,000 MILES
Hi guys, hope you can help me. My Landcruiser 2h diesel performs well until you turn a tight left at speed and a few moments up the road the engine momentarily cuts out and then refires and runs as normal with black smoke out the tail pipe for a moment. My hunch tells me that it is something to do with the deisel level changing somewhere by centrifugal force and possibly a water in diesel issue. Injectors are fine as performance is great other than left handers. Same effect with full or empty tank over many different tanks from different gas stations. I have already changed the fuel filter and with no joy. I would really appreciate a hand guys. Thanking you in advance. Jason.
Sunday, January 10th, 2010 AT 4:35 AM
GORDONMOB
G'day Guys. The problem was simple in hindsight. The engine was low on oil and when the car went around a corner the oil pump would suck air dropping the oil pressure. This in turn tripped the low oil pressure cutout switch and stopped the engine until pressure was regained then the engine refired. I hope this info helps someone else. See ya.
Monday, January 18th, 2010 AT 2:16 AM
THIS IS MIKE
  • 686 POSTS
We are glad you were able to figure out the problem, we have refunded your donation and hope we can help you the next time. Have a great day.
Monday, January 18th, 2010 AT 12:15 PM
