2003 Toyota Highlander Brake Squeak
LURCH730
I have a 2003 toyota highlander with 86,000miles. automatic/2 wheel drive. my problem is the my brakes squeak on one side and i have had all the brake pads replaced plus the rear rotors replced a year and a half ago from merchants tire. i have a warranty on it and i took it back to a different merchants tire by my house and they told me that my rear rotors need to be replaced. so i didn't get them replaced. so i took it back to the orginial place and they told me it was the rear caliper on the side that sqeaks. they said it was locking up. now if it is locking up wouldn't my tire not move and it would smell. also my car should pull to one side if i braked if the caliper was locking up right? Also could the sliding pins or bolts be replaced separately without replcing the whole caliper. i really don't feel like paying these people any more money if I don't have to especially sine i paid almost 700 dollars to replce the 2 rears rotors and all the brakes on front and rear. what should I do?
May 27, 2007 at 5:25 AM
LOSTINMARS
  • 222 POSTS
slide pins locking up on these is are a common problem. personally i would change the calipers as well. these are very hard to remove from the vehicle when the upper pin freezes up and some times the caliper needs to be hammered off.
Nov 3, 2007 at 6:53 PM
Suggested Repair
Replace the rear caliper on the squeaking side. Frozen slide pins are common on these Highlanders and can seize the caliper; a stuck upper pin often makes the caliper very hard to remove.
Conversation Summary
The owner of a 2003 Toyota Highlander reports one-side brake squeaking after pads and rear rotors were replaced about 18 months earlier. One shop recommended new rear rotors; the original shop said the rear caliper was locking up. The owner questioned that diagnosis and asked whether the slide pins or bolts could be replaced separately. The expert said seized slide pins are common and recommended replacing the calipers as well, noting a frozen upper pin can make the caliper very difficult to remove.
