2001 Toyota Highlander Oil Burning
MKALADGI
I have recently bought a 2001 highlander with 50K miles. It appears to be consuming oil, particularly during high speed driving, i.e. highway driving. Checked the PVC valve and apprears to be OK. Air filter is also good. No problems while running. No signs of any leakage. Can't see any blue smoke in tail pipe. Appears to vibrate a bit when idling, but great in Nuetral. Also, mileage is only about 17miles to a gallon. What else can I check before taking it to Toyota? Is this a known problem and will it cost me an arm and a leg? Please help !!!
May 15, 2007 at 8:08 AM
  • 75,988 POSTS
[quote:018b269168="mkaladgi"]I have recently bought a 2001 highlander with 50K miles. It appears to be consuming oil, particularly during high speed driving, i.e. highway driving. Checked the PVC valve and apprears to be OK. Air filter is also good. No problems while running. No signs of any leakage. Can't see any blue smoke in tail pipe. Appears to vibrate a bit when idling, but great in Nuetral. Also, mileage is only about 17miles to a gallon. What else can I check before taking it to Toyota? Is this a known problem and will it cost me an arm and a leg? Please help !!![/quote:018b269168]
If you're not leaking than its being burn internally-could be valve stems and guides. also I recommend you have the O2 sensors and the exhaust system check.
May 15, 2007 at 9:47 AM
Suggested Repair
If there is no external leak, treat the oil use as internal burning and have the valve stems and guides inspected. Also have the oxygen sensors and exhaust system checked.
Conversation Summary
The owner of a 2001 Toyota Highlander with 50,000 miles reports oil consumption mainly during highway driving, with no visible leaks or blue smoke. The PCV valve and air filter appear fine, idle vibration is noted, and fuel economy is about 17 mpg. The expert says the oil is likely burning internally, possibly through the valve stems and guides, and recommends checking the oxygen sensors and exhaust system.
