2002 Toyota Highlander P0128 Code
HIGHLANDER2002
Hi, any help is appreciated.
2002 toyota highlander.Automatic. 3.0 L V6 4wd. 100,000km.
Check engine light came on and my mechanic done a scan and ran this code P0128.
Mechanic said I probably need a new thermostat.
I went to the dealer to pick one up ($30.00) and he said he has never heard of that trouble with the highlander.
Toyota said they should have a look at it...Expensive...$100 just to scan for a code.
Confused at this point! Should I replace the thermostat and hope that was the problem? or let The dealer have a look?
May 15, 2007 at 5:24 AM
UNCLE FESTER
  • 13 POSTS
HIGHLANDER2002
Thanks . I had a look at the chart. I am not really sure what it all means.
My car knowledge is minimal. What is ECM. How much is one and ? labour time.
When the light came on the car was running for about 5 minutes
when they scanned that was the only code that came up.
Thanks again. Newbie
May 15, 2007 at 6:02 AM
  • 75,988 POSTS
That code is pointing at the thermostat being below the operating temperature.
The ECM ( Electronic Control Module ) is the Computer.
May 15, 2007 at 9:54 AM
HIGHLANDER2002
So should I just replace the Thermostat? Thanks Mb
May 15, 2007 at 10:26 AM
  • 75,988 POSTS
[quote:c545f81b6d="highlander2002"]So should I just replace the Thermostat? Thanks Mb[/quote:c545f81b6d]
Its a cheap fix go ahead and do so for a start.
May 15, 2007 at 11:27 AM
ZONER CHICK
  • 19 POSTS
You said your mechanic did a scan. Is that all that he did? Coolant level can also cause this light.
Check the coolant level, if it's low you need to find the leak and fix it If leak is at thermostat or water pump, you may as well change them. 100,000 is quite a bit of mileage. Refill cooling system, clear the code and see if it comes back.
If it does, change the thermostat if not already done. Refill, Clear, See if code comes back.
If it does, don't jump right to the ECM. Check the ECT (Engine Coolant Temperature) Circuit first. Basically it's the ECT sensor and the wiring to the ECM. If not the ECT you'll be looking at a ECM.
May 17, 2007 at 4:23 PM
Suggested Repair
Start with the inexpensive thermostat, since P0128 indicates the engine is not reaching operating temperature. Also check the coolant level and repair any leak, including the water pump if that is the source. Refill the cooling system, clear the code, and see whether it returns. If it does, test the engine coolant temperature sensor and its wiring before considering the ECM.
Conversation Summary
A 2002 Toyota Highlander with about 100,000 km set code P0128 after a short run. The mechanic suspected the thermostat, while the dealer had not commonly seen that issue and wanted a paid scan. Experts explained that the code points to the engine running below operating temperature and that the ECM is the engine computer. They recommended replacing the thermostat as a cheap first step, checking coolant level and leaks, then clearing the code. If it returns, check the ECT sensor and wiring before replacing the ECM.
