2001 Toyota Camry Brake Noise
PRM55
Toyota Camry V6 2001 97k
Recently the brakes and rotors were changed but there is a noise when the brakes are pressed
The brakes are toyota brand, the rotors are not
What could be problem and how could it be solved?
thanks
Apr 11, 2006 at 3:15 PM
LOSONE
  • 1,616 POSTS
Give it a little time. I had the same problem. It took about 700 miles for the pads to seat to the non Toyota rotors. Good luck
Apr 12, 2006 at 12:05 AM
Suggested Repair
Allow the new Toyota pads time to seat against the non-Toyota rotors. Similar noise cleared after about 700 miles of normal driving.
Conversation Summary
The owner of a 2001 Toyota Camry reports brake noise after recently replacing the pads and rotors. The pads are Toyota brand and the rotors are not. The expert says the same issue resolved after about 700 miles as the pads seated to the non-Toyota rotors.
