High RPM's on a Toyota Camry
TNONG84
  • TOYOTA CAMRY
1. Make and Model of your car-1992 v6, toyata-camry
2. Include the mileage-102000
3. Stick shift or automatic transmission-automatic transmission
4. 2 or 4 wheel drive-4wheel drive
5. Strange sounds-nope
6. Fluid leaks-nope
7. Past repair history if applicable-none
here is my problem and I need help trying to repair it. The car runs fine but when I drive it for like 15 minutes it start being wierd. The rpm's is getting higher then it should be. When I have it on drive the rpm's is high, and useally when you stop you shift to nautral the rmp's went really high. So I was wondering what is wrong with it. And then one day when I was driving it, I think the engine got too hot and I was coming to a red light and it was hard for me to stop. I try to push really hard on the brakes. And then I pull over and look under the hood. I notice that my fan isnt working. And I accidently touch my radiator and it was really hot. To summarize it all, my rpm's was high and I dont think my fan is working. So can someone tell me what I need to do.
thanks alot.
Tuesday, May 15th, 2007 AT 4:12 PM
Try cleaning the idle air control valve and the throttle body plate-also check for a stretch accelerator cable or needing adjustment.
Check the coolant temperature and throttle position sensors
Tuesday, May 15th, 2007 AT 4:37 PM
2CARPRO JACK
  • 11,533 POSTS
Might also want to look at the vacuum line from the engine to the brake booster
Tuesday, May 15th, 2007 AT 6:11 PM
