1995 Toyota Camry high idle
NOVELL21
  • 1995 TOYOTA CAMRY
Engine Performance problem
1995 Toyota Camry 4 cyl Automatic 132560 miles
my car had low idle speed on cold start up, sometimes it used to die immediately on cold start up or when put into drive; then I replaced the idle air control valve but now the idle speed is high (about 2000 rpm) when in parking gear; but seems fine in drive. What could be the problem and solution. Thanks
Friday, October 29th, 2010 AT 10:25 PM
MADMIKE1735
  • 951 POSTS
Sounds like a vacuum leak. Did u remove the throttle body or intake tube prior to replacing the IAC? It may be as simple as a loose hose clamp, or pinched gasket.
Friday, October 29th, 2010 AT 11:01 PM
NOVELL21
First I had to open the air intake tube and then the throttle body to replace the IAC. I have done it twice and its the same problem both times.
Saturday, October 30th, 2010 AT 12:54 AM
