Okay I checked all the front two side. The rotors for thickness which iwas in range and check for warpness. Didnt find any at that, I check the calipers for movement, or frozen and brake pads. Greased everything. All seems to slide okay. Air bled out. I didnt get to look at the drums yet again.. But after I looked and greased up the front. I took it out. And it still vibrates to a point. I dont think its as bad, but might be my imagination. The pedal still pulsates. Some. And it still shudders when you brake at higher speed. Sometimes the steering vibrates too. Could it be a tire out of balance or steering or. I still need to look at the drums? Im sure anything can do it, but what would you recommend I look at next? I really need to figure this out. I apreciate any help thanks!
Sunday, August 5th, 2007 AT 3:37 AM
