1989 Toyota Cressida No Power After Wash
HOCKEYMAMA2007
I washed the engine on my just purchased 1989 Toyota Cressida and now it has absolutely NO power, it runs, but it can't go far because there is not enough power to go fast enough. HELP what is the problem, how can I fix it?
1989 Toyota Cressida 178000 Km 6cyl 24 valve
Sep 11, 2007 at 4:09 PM
  • 31,937 POSTS
Hi there,
Just washed the motor, take of the distributor cap and check for condensation, also clean the hi tension lead ends where they go into the cap, these will corrode and cause a problem. check that the spark plug terminals are also dry & clean.
Mark (mhpautos)
Sep 11, 2007 at 4:51 PM
Suggested Repair
Remove the distributor cap and check for condensation. Clean the high-tension lead ends where they enter the cap, and make sure the spark plug terminals are dry and clean.
Conversation Summary
The owner of a 1989 Toyota Cressida said the engine runs but has almost no power after being washed. The expert advised checking the distributor cap for condensation, cleaning the high-tension lead ends, and confirming the spark plug terminals are dry and clean.
