1991 Toyota Cressida Low Idle
RAYRATLIFF
I have a 1991 Toyota Cressida, straight 6, 110,000 miles. The engine idle will not come up to its proper 750RPM when engine is at operating temp. No Oxygen sensors have ever been changed. Which sensors could be causing the slow idle? I am selling this car and I want to make sure everything is in good working order before I sell to someone.
Thank You...[img:508352a783]http://www.2carpros.com/forum/automotive_pictures/54067_CressidaEngine_1.jpg[/img:508352a783]
Jan 15, 2007 at 9:39 AM
BRUCE HUNT
  • 3,754 POSTS
Is there good pressure on the clutch pedal? Miles on the clutch? This could be a throwout bearing and fork issue.
Nov 7, 2006 at 11:06 AM
SERVICE WRITER
  • 9,123 POSTS
ecu, cts,tps all are inputs, the isc valve would be my suspicion located on the air intake system.
Jan 15, 2007 at 10:15 AM
Suggested Repair
Inspect and test the idle speed control (ISC) valve on the air intake. Also check the coolant temperature sensor, throttle position sensor, and ECU inputs that control idle.
Conversation Summary
The owner of a 1991 Toyota Cressida with 110,000 miles reports that idle does not rise to the proper 750 RPM at operating temperature and asks which sensors could cause it, noting the oxygen sensors have never been replaced. One reply discusses clutch pedal pressure and a possible throwout bearing or fork issue, which does not address the idle complaint. Another identifies the ECU, coolant temperature sensor, and throttle position sensor as inputs and suspects the ISC valve on the air intake.
