1997 Toyota Corolla Timing Belt Change Guide
SPYURA
I have Corolla 97 1.6L
the question is if somebody know how to change the timing belt and water pump???
maybe someone has a guide how to do it?
Thank you!
email to : spyura@gmail.com
Nov 4, 2007 at 12:16 PM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_camry_1.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_camry1_1.jpg
Nov 4, 2007 at 12:25 PM
SPYURA
ok but how to do it... do you have the points... like the first what I need to do, after that the second thing...
Thank you! I really appreciate your help!
Nov 4, 2007 at 4:31 PM
MMPRINCE4000
  • 8,548 POSTS
It is best to buy a Haynes manual. You can pick one up at Advance Auto for $16.00. It has the complete procedure with pictures.
When you replace the waterpump (on some models) you have to lift the engine up to remove the waterpump pulley, so if you don't have a cherry picker or equivelent, you would need to rent one.
Also make sure the WP replacement has 2 Orings, one for the block and one for the housing.
Nov 4, 2007 at 11:00 PM
Suggested Repair
Buy a Haynes manual for the complete timing belt and water pump procedure with pictures. On some models the engine must be lifted to remove the water pump pulley, so use a cherry picker or equivalent if needed. Confirm the replacement water pump includes two O-rings, one for the block and one for the housing.
Conversation Summary
The owner of a 1997 Toyota Corolla 1.6L asked for a step-by-step guide to replace the timing belt and water pump. An expert recommended a Haynes manual from an auto parts store and noted that some models require lifting the engine to remove the water pump pulley. The replacement pump should include two O-rings, one for the block and one for the housing.
