1992 Toyota Corolla High Idle
OMARAJ
I apollogise for not following the protocal for facilitating quick response, but I really need your help. An amature is I who bought this car (Toyota Corolla FX, Model AE101 1992, engine 1587cc, milage 110450km) three months back without profesional advice and check up by a knowledagble person in automobiles. The car's idle can go as high as1750 rpm. Also, it is a manual transmission and when I shift gears, the engine rpm remains high instead of going lower during the shift. It has been cunsumed alot of coins from me to my disappointment. Repalced are: fuel pump and filter, air filter, plugs. I've read about similar problems and most recomendations for remedy are centered around MAF sensor/AIS, oxygen sensor. I have then asked my mechanics about these gadgets and they seem to be hearing this for the first time in their lives. Being a car of decade and half, do these MAF sensor, AIS, oxygen sensor exist in my car. If yes. where are they located? If no, what can really cure this annoying problem? I promise to be supportive to this great services you are offering. Poor John In Kampala Uganda.
Jul 13, 2007 at 5:51 AM
  • 75,988 POSTS
[quote:16cbe28fc9="Omaraj"]I apollogise for not following the protocal for facilitating quick response, but I really need your help. An amature is I who bought this car (Toyota Corolla FX, Model AE101 1992, engine 1587cc, milage 110450km) three months back without profesional advice and check up by a knowledagble person in automobiles. The car's idle can go as high as1750 rpm. Also, it is a manual transmission and when I shift gears, the engine rpm remains high instead of going lower during the shift. It has been cunsumed alot of coins from me to my disappointment. Repalced are: fuel pump and filter, air filter, plugs. I've read about similar problems and most recomendations for remedy are centered around MAF sensor/AIS, oxygen sensor. I have then asked my mechanics about these gadgets and they seem to be hearing this for the first time in their lives. Being a car of decade and half, do these MAF sensor, AIS, oxygen sensor exist in my car. If yes. where are they located? If no, what can really cure this annoying problem? I promise to be supportive to this great services you are offering. Poor John In Kampala Uganda.[/quote:16cbe28fc9]
Mr. John
Your vehicle involves electronic engine controls meaning sensors/actuators/computer take it back to the mechanic and have clean out the throttle body/plate to include the idle air control valve-The MAF sensor can be very pricey
BTW have him pull the code/s by jumping the diagnostic connector TE-1 to E-1 this will reveal the codes by reading the flashes on the check engine light
Jul 13, 2007 at 8:12 AM
Suggested Repair
Have a mechanic clean the throttle body and throttle plate, including the idle air control valve. Retrieve stored codes by jumping diagnostic connector terminals TE1 to E1 and reading the check engine light flashes. The MAF sensor, if present, can be expensive.
Conversation Summary
The owner of a 1992 Toyota Corolla reports idle as high as 1750 rpm that stays high during manual gear shifts. The fuel pump, fuel and air filters, and spark plugs were already replaced. The expert says the car uses electronic engine controls and recommends cleaning the throttle body, plate, and idle air control valve, plus pulling diagnostic codes.
