2002 Toyota Corolla High Cold Idle
VASYA22
When the engine is cold (has been off for several hours) it starts at very high RPM (over 2000) and it takes about 7-10 minutes before it drops to about 1100. This is my first Toyota so I don't know if this is normal. All my previous cars never started at such a high RPMs. Any advice please?
Thanks!
May 9, 2007 at 5:03 PM
  • 75,988 POSTS
[quote:00a71b4994="Vasya22"]When the engine is cold (has been off for several hours) it starts at very high RPM (over 2000) and it takes about 7-10 minutes before it drops to about 1100. This is my first Toyota so I don't know if this is normal. All my previous cars never started at such a high RPMs. Any advice please?
Thanks![/quote:00a71b4994]
Could be the cold start injector time switch failing or the throttle plate sticking-could also be the coolant temperature sensor or the thermostat prolonging the open loop feedback.
May 9, 2007 at 5:53 PM
VASYA22
[quote:72b4905136="rasmataz"]Could be the cold start injector time switch failing or the throttle plate sticking-could also be the coolant temperature sensor or the thermostat prolonging the open loop feedback.[/quote:72b4905136]
Thank you for fast reply. But would the problems you described cause only slow RPM drop, but not a very high initial RPM?
May 9, 2007 at 6:02 PM
  • 75,988 POSTS
Check the areas that I've mentioned then we'll go somewhere else if it checks out.
May 9, 2007 at 10:32 PM
Suggested Repair
Check the cold-start injector time switch, a sticking throttle plate, the coolant temperature sensor, and the thermostat, which can prolong open-loop operation and keep cold idle high.
Conversation Summary
The owner of a 2002 Toyota Corolla reports cold starts above 2000 RPM that take 7-10 minutes to fall to about 1100 and asks if that is normal. The expert suggests checking the cold-start injector time switch, throttle plate, coolant temperature sensor, and thermostat before looking elsewhere.
