Toyota Corolla Brake Lights Out
DILLAQ
Here's my question: I had a guy stop me and say that my brake lights were not working....check fuses and bulbs they are all ok. The blinkers and the hazard lights also work fine. Could you advise me on what may be the problem and what to do.
Thanks
Erica
Nov 21, 2007 at 5:52 AM
  • 31,937 POSTS
Hi there,
Check the brake light switch. This switch is mounted at the top of the brake pedal arm, it has two wires one should be 12V and the other goes to the brake lights. To prove the circuit remove wires and jump together with wire, don't let the bare wire touch earth (car metal) with ignition on and power at 12v wire brake lights should work. If not there is a fault in the wiring, If working the fault is in the switch or the adjustment of the switch.
Mark (mhpautos)
Mar 17, 2021 at 11:08 AM
Suggested Repair
Check the brake light switch at the top of the brake pedal arm. With the ignition on, confirm one wire has 12V and briefly jump the two switch wires together without letting them touch metal. If the brake lights then work, replace or adjust the switch; if not, look for a wiring fault.
Conversation Summary
The owner of a Toyota Corolla was told the brake lights were not working. Fuses and bulbs checked out, and the turn signals and hazard lights still worked. The expert advised testing the brake light switch on the pedal arm by confirming 12V and jumping the two wires; working lights point to the switch or its adjustment, while no lights point to a wiring fault.
