2000 Toyota Corolla Headlights Wrong Time
JKRUMP
2000 Corolla LE, 110,000 miles.
Running headlights turn on during day instead of night. Manual headlight switch will turn headlights on during day but not at night. Fuses fine. Bulbs of course fine. Replaced headlight relay already.
Note: switch will turn on parking lights day or night.
Nov 14, 2007 at 10:44 AM
FISHERMAN
  • 937 POSTS
[quote:6fcecbdff9="jkrump"]2000 Corolla LE, 110,000 miles.
Note: switch will turn on parking lights day or night.[/quote:6fcecbdff9]
Hello!!
Check the following:
automatic light control sensor (on top left side of dash)
and daytime running light relay (main) (behind dash above glove box)
the sensor and the main relay are responsible for the issue you had.
i would start checking the relay.
let us know if you want the complete schematic (wiring diagram)
good luck!
Nov 14, 2007 at 12:53 PM
Suggested Repair
Check the automatic light control sensor on the top left of the dash and the main daytime running light relay behind the dash above the glove box. Start with the relay.
Conversation Summary
The owner of a 2000 Toyota Corolla LE reports that the running headlights come on during the day instead of at night, while the manual switch turns the headlights on by day but not at night. Parking lights work day or night, and the fuses, bulbs, and headlight relay have already been checked or replaced. The expert recommends checking the automatic light control sensor and the main daytime running light relay, starting with the relay.
