1991 Toyota Corolla Brake Batt Lights
SHUCKER
1991 Toyota Corrolla, 1.6 engine, 180,000 miles, air, auto.
The "brake" and "batt" lights illuminate intermittantly together, dim and bright. Sometimes they flash on and off. Car starts great, had the alternator checked on a machine at my local parts dealer, checked good. Battery voltage checks good and is being charged with engine running. Running down the road, the lights come on and off. Everything appears to be working ok. Both of these lights come on at the same time, when driving down the road.
Sep 1, 2007 at 6:49 AM
  • 75,988 POSTS
[quote:9d76aa10b7="shucker"]1991 Toyota Corrolla, 1.6 engine, 180,000 miles, air, auto.
The "brake" and "batt" lights illuminate intermittantly together, dim and bright. Sometimes they flash on and off. Car starts great, had the alternator checked on a machine at my local parts dealer, checked good. Battery voltage checks good and is being charged with engine running. Running down the road, the lights come on and off. Everything appears to be working ok. Both of these lights come on at the same time, when driving down the road.[/quote:9d76aa10b7]
Battery voltage checks good and is being charged with engine running. What's the voltage reading?
Sep 1, 2007 at 9:25 AM
SHUCKER
[quote:7e967baff7="rasmataz"][quote:7e967baff7="shucker"]1991 Toyota Corrolla, 1.6 engine, 180,000 miles, air, auto.
The "brake" and "batt" lights illuminate intermittantly together, dim and bright. Sometimes they flash on and off. Car starts great, had the alternator checked on a machine at my local parts dealer, checked good. Battery voltage checks good and is being charged with engine running. Running down the road, the lights come on and off. Everything appears to be working ok. Both of these lights come on at the same time, when driving down the road.[/quote:7e967baff7]
Battery voltage checks good and is being charged with engine running. What's the voltage reading?[/quote:7e967baff7]
12 volts static, about 13.5 running with alternator.
Sep 1, 2007 at 11:50 AM
  • 75,988 POSTS
[quote:eae1ffa47f="shucker"][quote:eae1ffa47f="rasmataz"][quote:eae1ffa47f="shucker"]1991 Toyota Corrolla, 1.6 engine, 180,000 miles, air, auto.
The "brake" and "batt" lights illuminate intermittantly together, dim and bright. Sometimes they flash on and off. Car starts great, had the alternator checked on a machine at my local parts dealer, checked good. Battery voltage checks good and is being charged with engine running. Running down the road, the lights come on and off. Everything appears to be working ok. Both of these lights come on at the same time, when driving down the road.[/quote:eae1ffa47f]
Battery voltage checks good and is being charged with engine running. What's the voltage reading?[/quote:eae1ffa47f]
12 volts static, about 13.5 running with alternator.[/quote:eae1ffa47f]
Charge the battery and get it up to 12.8. When its there load test it-using the starter for 10secs if it drops below 9.6 volts-replace the battery no good-
Belt tension good?
Sep 1, 2007 at 12:40 PM
Suggested Repair
Charge the battery to about 12.8 volts, then load-test it by cranking the starter for 10 seconds. Replace the battery if voltage drops below 9.6 volts. Also verify that the alternator belt tension is good.
Conversation Summary
The owner of a 1991 Toyota Corolla reports that the brake and battery warning lights come on together intermittently, sometimes dimming, brightening, or flashing while driving. The car starts well, the alternator tested good, and voltage was about 12 volts static and 13.5 volts running. The expert advises charging the battery to 12.8 volts, load-testing it with the starter, replacing it if voltage falls below 9.6 volts, and checking belt tension.
