1995 Toyota Corolla Dash No Power
JROMANO28
  • 9 POSTS
I have a 95 toyota corolla with 86,000 miles on it ,and a couple months ago i put in a radio ,the next morning i drove to work and when i turned on my headlights and i heard a pop like a fuse and that day i checked the fuse and the problem is now i dont get power to the dashborad and instrument panel just power to the headlights. people tell me its a multifunction switch ,how would i know what it is and to test to see if thats the problem
Nov 19, 2007 at 11:27 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e813f1a84e="JRomano28"]I have a 95 toyota corolla with 86,000 miles on it ,and a couple months ago i put in a radio ,the next morning i drove to work and when i turned on my headlights and i heard a pop like a fuse and that day i checked the fuse and the problem is now i dont get power to the dashborad and instrument panel just power to the headlights. people tell me its a multifunction switch ,how would i know what it is and to test to see if thats the problem[/quote:e813f1a84e]
use a testlight to test the fuses turn light on and check fuses does the radio work ok
u may have wired the light wire to a ground
Nov 19, 2007 at 12:08 PM
Suggested Repair
Use a test light to check the fuses with the lights on, and confirm whether the radio works. The light wire may have been connected to ground during the radio installation.
Conversation Summary
A 1995 Toyota Corolla lost power to the dashboard and instrument panel after a radio installation and a pop when the headlights were turned on; the headlights still work. The owner was told it might be the multifunction switch. The expert advised testing the fuses with a test light while the lights are on, checking whether the radio works, and considering that the light wire may have been wired to ground.
