2000 Toyota Corolla No Power
DLANHLEO
Hi
My friend has a 2000 corolla (100k km). As the car is idle , it run fine. But as pressing the gas pedal, it is no power. even pedal all the way down. It have engine light on and kind bad smell at muffler. I think the caltelic converter is blocked. Is it right? thank for your help
Dec 17, 2006 at 2:33 PM
  • 75,988 POSTS
Disconnect the exhaust pipe up front or connnect a pressure gauge where the oxgen sensor is-anything over 3lbs calls for concern.
Dec 17, 2006 at 3:48 PM
LOSONE
  • 1,616 POSTS
Before you disconnect an exhaust system you may need to check the timing. Those years were bad about belts/chains as it was the cross over year. If a belt and the little engine it,s timing belt time.
let me know losone
Dec 18, 2006 at 5:51 AM
Suggested Repair
Check exhaust backpressure with a gauge at the oxygen sensor (over 3 psi is a concern) or by disconnecting the front exhaust pipe to test for a restricted catalytic converter. Before disconnecting the exhaust, also verify engine timing, since these years were prone to timing belt or chain problems.
Conversation Summary
A 2000 Toyota Corolla idles normally but has no power when the accelerator is pressed, with a check engine light and a bad smell at the muffler. The owner suspects a blocked catalytic converter. Experts recommend measuring exhaust backpressure or disconnecting the front exhaust to check restriction, and checking timing belt or chain timing first because that model year was a crossover with known timing issues.
