1997 Toyota Corolla Dash Gauge Lights
JITR
the light on the instrument panel where the gas guage and speed guage is wont come on. Cant find the fuse related to it...
Oct 5, 2007 at 12:47 PM
FAIRRACING31
  • 150 POSTS
If your other dash lights are working its most likely a bulb and not a fuse. Sometimes the printed circuit goes out but not very offen.You will have to remove your instrument panel to access the bulb or bulb's.
Oct 5, 2007 at 12:59 PM
Suggested Repair
If the other dash lights work, the gauge illumination is most likely a failed bulb rather than a fuse. Remove the instrument panel to access and replace the bulb or bulbs. A failed printed circuit is possible but uncommon.
Conversation Summary
The owner of a 1997 Toyota Corolla reports that the instrument panel light for the fuel and speed gauges will not come on and cannot find a related fuse. The expert says that if the other dash lights work, it is most likely a bulb rather than a fuse, and the instrument panel must be removed to reach it. A printed circuit failure is possible but uncommon.
